P
Poco
"First, on the analog side of the converter, just like with any other analog preamp, if you push the signal too hot, you get distortions"
Mr. Stephan, your experience notwithstanding, I would like to hear that from the designers of the A to D's in my MX2424. In essence, you are telling us that if we use this gear to its full extent and within its operational design we will get distortion? I find that difficult to believe. In fact, I don't believe it. If a clean analog signal goes in, I am thoroughly convinced a clean digital representation of that signal will be written to the disk, regardless of the level (assuming no clipping has occurred).
If our input devices generate noise when they are turned up (simple way of putting it), we need better input devices.
To those of us who's only analog output post recording is the CD player, the rest of your explanation does not seem to apply. For me, anything post recording is purely math.
Also,
If I set my loudest signal at some 70 to 80 percent of my equipment's potential, my quietest signal will surely fall off the scale altogether. I mean, a chief complaint of recording technology is not that it has too much dynamic range, rather, just the opposite. Ask anyone who has recorded an orchestra. What the human ear can hear, and what current technology can capture are two vastly different things. Why exacerbate the situation?
From the makers of Alesis digital recorders:
"Setting the correct recording levels is crucial to
making any recording sound its best. On any
digital recorder, the best resolution is found
when the maximum recording level of each track
falls just below the “Clip” point."
They said "any digital recorder" Did the Alesis engineers protest this statement? Did someone just miss this very important section of the manual?
I bought a device that records from 0 to 100%. I think I should be able to use it that way to no detriment. If that is not the case, there should be a professional disclaimer "Caution, you should only use 70% of this device's recording potential"
It's my dynamic range. I'm keeping it.
Thanks,
Poco
Also,
Thanks,
Poco
