Much better.
The guits are defined and crunchy. But the execution is a little sloppy:
Like the sustaining tag-ends of the chords....they don't end consistently on the same beat, for example...in where they oughtta be...but lazy going out. A little more chug chug and tightness in the ends of the phrases would punch it up.
Vox up. Good!
The bass sound and level are not so good, yet. It's sort of there...but not defined, and certainly not working together, sound-wise, with the BD.
I'd add the next third up on the chorus background vox....get out the visegrips
When the chorus hits, there needs to be another element to 'break it out'...some kind of sustaining or pedaling bass, synth, or vox parts to accompany the vox you have [they fail in the attempt to really let the chorus out of the box]. Also, snipping the guitar's phrase-endings in the verses...chug chugging it ....would be a better contrast between the short, businesslike parts in the verse, and a breakout sustain in the chorus, I think.
You might like to devise a couple signature guitar lines...harmonized? to play in some flat spots where there's not much happening.
The two-note pulls between the chords aren't working. They're a good idea, but I think they should be tracked over the rythm part, so they sustain and ring into the next few beats. Cheating, I know. But the transition on the same guit is abrupt and uncomfortable.
Getting there. Good work.
There are a couple heavy death metal submissions on page one that have the power in the bottom this tune needs to get off the runway. You should give a listen...great references!!
BTW...you have real good hands on the neck. Work on the phrasings of your lines. They tend to start on the one, and end on the four. It's like you're reacting to the changes instead of driving them like a rabid cowboy. Melodic flourishes that jump the bar lines and anticipate the changes are interesting .... da bomb. You play a lot of notes really well. Just think about where you want to place them to get to a next level. Try an experiment: slide the solo part two beats forward...listen. Might be some good examples of change anticipation and over-the-bar-line genius. Maybe not.... :^)
Hey! Try chorus effect on the chorus b'ground vox, instead of the cave!!
