R
Robert Wall
Gene Lawson put a blurb on his website's newspage about the operation of a large condenser capsule. It was fun to imagine, and helpful to visualize, but flawed, I think, in its arithmetic.
He said,
" Condenser microphones are the most accurate microphones in terms of frequency and transient response because they use extremely light-weight diaphragm materials which are moved easily by sound pressures. Diaphragm motion in the presence of normal sound pressures is microscopic. To give an idea of the scale of diaphragm motion in a condenser microphone, let's increase the dimensions of the capsule by 1 million times and assume a sound pressure level of 74 dB (conversational level). The diaphragm would then be almost ten feet thick. The diaphragm to backplate spacing would be 142 feet, and the capsule would be 22 miles in diameter. The diaphragm motion would only amount to 1 millimeter (4/100 of a inch)! You can see that the diaphragm motion is truly microscopic and that the condenser microphone is very efficient at converting these small diaphragm motions into electrical outputs. "
OK.
Since Gene's diaphragms are 3 microns thick, and since that is 3/1000 of a millimeter, and since there are about 25 millimeters in an inch, multiplying the 3 microns by one million and converting to inches and feet, it comes out to about 10 feet. So far, so good.
Gene's LDC mikes use a 1" capsule. A million inches= 83333.33 feet and that's 15.78 miles rather than Gene's 22. Oops! But it's still a pretty big capsule !
This is where finishing the image gets real foggy. Unless we know the overall thickness of the capsule, the actual backplate spacing and the actual measured amount of diaphragm deflection in response to the stated sound pressure, we can't really know if his (x 1 million) diaphragm motion claim of 1mm is accurate.
And frankly, if it were MY microphone I was blowing up to 1 million times its real size, should I give you truly accurate numbers ? Wouldn't I be giving away the farm in re: distance from diaphragm to backplate and diaphragm tension, etc. ? Isn't that the secret stuff ?
I'd like to see this illustration complete and be able to verify the numbers myself. See -- if you go back to Gene's numbers and divide his 1mm diaphragm motion number by a million, it comes out to .001 micron. That's a millionth of a millimeter !
Is that as far as the sucker really MOVES ???
The only guy I know who could answer this is Stephen Paul, but if he told me he'd have to shoot me. (Just kidding.)
Anybody?
He said,
OK.
Anybody?
