briank
analog for the people!
Ah, this is what I intended to do.
What I meant was this- I would record 4 separate tracks on 2 separate tapes, 4 on each tape. I would run each tape separately into one file in Audacity, so I can use a 4 track recorder to create a song with 8 tracks, then burn it to CD. IS this doable?
Ah, yes, this could indeed be made to work...but the caveats are that with no time synchronization, you'll be lining them up as carefully as you can by ear...and you will have to be clever about how you monitor the previously recorded tracks while you are performing the other "set" of four tracks for the song.
Personally, I still advise you to walk before you run--get the hang of four tracks first before you try "cheating the system" as it were
Others may disagree...
