L
lockesilver
I use SONAR LE right now and more often than not record myself doing voiceover or singing. Sonar is quite convenient to use but I often end up doing 30-50 takes of something and then have it all scattered around in various tracks.
I record something, go to the keyboard, move it manually to a place on another track where it won't be getting in the way, press record and return to the mic. And then I absolutely can't find the one take from half an hour ago that I remember was nice.
Is there a way to simplify this? Is there a DAW with a Library panel where I could move unused clips? My ideal workflow would be as follows:
I record something, press a button on the keyboard (or even better a DAW controller), listen to the clip and with another button I move to the library. I press record again, record, etc. Much faster and more effective.
So in the end instead of 6 tracks cluttered with a myriad of random takes I have the initial 'background' tracks untouched and a library full of recorded clips (ideally sorted into categories).
