Okay, I had heard that they might do a good job on choral recording. I recorded this earlier today at my Old Highschool.
Here's my setup:
I used a pair of the ECM8000's on boom stands about 10' up and 25' apart.
They were positioned about 5 ft in front of the choir which sat about 35' wide in the room.
The mics were pointed in at 45 degrees and at a slight tilt down towards center.
The room is approx 35' deep and 45' wide and 20 ' tall.
The floor is asphault tiling and the ceiling is stardard school-issue Drop-ceiling.
The choir is positioned in the center of the room spread out along the wide span of the room.
I used a Behringer MX 802A mixer and paned the mics hard Left and hard Right respectively to attain the stereo image of the choir.
The recorder used was a Roland XS-880 XVpanded DAW. The piano used is a Kawai digital piano. I also ran the output from the piano into the DAW and centered the panning to reinforce the piano sound. I used a minimal amount of DI piano sound in the mix.
No effects have been added to the recording and all reverb is the natural reverb of the room. All EQ was done on the Mixer before entering the DAW.
I would have liked to move the mics back about 10 - 20 ft in order to get better blend but obviously the room size could not permit such an arrangement.
I am looking for comments on this "sound" that I was able to get with these two mics. Any ideas on EQ or other things that I could have done differently would be appreciated as I am just a learning beginner on mixers and this is my first mixer.
Song located here:
http://www.nowhereradio.com/artists/album.php?aid=1934&alid=264
Thanks- Brent
Here's my setup:
Song located here:
Thanks- Brent
