M
Mark H.
Don, John, please help.
Thank you all for this great information on using rigid fiberglass insulation instead of expensive foam applications.
I have a few newbie questions I hope you can answer:
1.) I live in an area where burlap would definitely not work. Would there be any sonic reason that I could not use some of the synthetic silks instead? They're lightweight, inexpensive, and would have a much higher WAF (wife acceptance factor).
2.) The panels in the pictures look like they are only about 2" thick; is there any reason not to use thicker insulation, if available? Is 2" enough?
3.) What's the difference between "rigid" fiberglass and the pink stuff in my attic, other than the thickness? Can the latter be used, or does it sag under its own weight in vertical applications, or does the silvered cover defeat the sound-absorbing qualities?
4.) I realize each room is potentially unique and that treating it requires experimentation -- I'm OK with moving stuff around and listening. However, are there "general" guidelines on how much wall/ceiling to cover? Are you looking to make your studio "dead" (I assume not, except perhaps for a small booth for very dry vocals), or simply to remove nodes, or to find (by ear, I assume) a generally pleasing balance?
I know when answering others that sometimes a poster doesn't know enough about the topic to ask the right question -- if that's the case with me, please answer the questions I should have asked instead!
Thank you for your help and for your pictures.
With kind regards,
Mark H.
With kind regards,
Mark H.
