E
ecc83
Oooo! Matey! You used the 'R' word. No matter the sample rate nor word length the RESOLUTION is still one bit = approx 6dB.
We know we can feel bass that we cannot hear....
......coming out of my $2 earbuds.
Could be, after all, the number of samples doubled and the bit depth went from 16 to 24. Could also have been just a much better quality pre in the Presonus unit : )
Yes.Am I the only one that looks at that and sees someone needing dental work?.
I'll drop in a warning- a guy who gets cited a lot is Oohashi, who did some experiments which supposedly demonstrated that brain wave differences could be measured when bandwidth was extended past the canonical 20kHz. Unfortunately, not only were his controls questionable, several attempts by other groups to replicate his work showed null results. That doesn't stop hucksters with something to sell from citing it anyway...
Reality: if you're a musician, you're unlikely to be able to even hear 20kHz. So anything beyond a 44.1 is for bragging or marketing, not actual sound.
Reality: Very, very few mikes have frequency responses that go into the ultrasonic range being discussed. The two that I've reviewed which do are unsuitable for recording anyway because of their noise floor (engineering = tradeoffs).
Reality: There's no good experiment out there, none, zilch, nada, which supports audibility of increased sampling rates.
One other comment- the reason for using 30 ips for analog tape is extended headroom, lower distortion, and lower noise floor. 44.1 vs 48 vs 96 vs 192 doesn't address that at all. Analog tape is a bad, errrr, analogy.
i have an opportunity to replace my old 96k audio interface, wondering if anyone has any real experience with a 192k interface, if it’s worth the extra cash?
Thanks
