mshilarious
Banned
gullfo said:i threw together some samples on my soundclick site for 96/24 vs 44.1/24 and 16 vs 24 bit. you can take a listen. http://www.soundclick.com/roughcanvas - in the music section - top 4 items. ignore the rest. i deliberately left a lot of room noise in because i think you can more easily hear the overall difference in the noise in addition to the guitar bits... the 16 vs 24 (IMHO) is obvious. the 96 vs 44.1 is subtle but even in MP3, the source difference is there...
16 v 24 is not at issue, and I don't think too many would argue for 16 at this point--the specs in noise floor are dramatically different.
So I just listened to the 44.1 vs. 96 samples. These performances are too different, both samples are very quiet, and the .mp3 files are low rate. I don't think this is a very valid test--try using something repeatable, like a CD.
Incidentially this is the FFT of the two files, blue is 96 and yellow is 44. The 44 sample is 3.4 dB louder than the 96, both peak and RMS, which I didn't normalize on this graph, because it makes them easier to read.
In theory, we should expect to see a slight attenuation in the 44 file above 18 kHz. It's not there, but again the level up there is -90dB or so, so there may have been practically no signal to be attenuated.
