triple-zero said:
any tips on tuning a kit?
Well, here's how I start:
Take the drum and put the batter head (the side you beat on) down on a carpeted floor.
Start with the resonant head completely loose.
You will need:
1 Pencil with a pencil eraser.
1 Drumkey
1. Tighten the tension rods finger-tight.
2. Then squeeze the hoop toward the drum, by hooking your fingers over the back of a lug, and hooking your thumb on top of the hoop. then tighten that particular lug. I suggest the "star" pattern - which means you the next lug you tighten will be directly a cross from the first one. then the third lug you tighten will be next to the second one, and the fourth lug you tighten will be directly across the drum from the third one.
Once you have gone all the way around the drum, then tap about 1" from each lug with the pencil eraser. Then use the key to fine tune each lug. (The pencil gives you pure tone - if you use a stick, you hear a heavy attack.)
This will be the lowest note the drum will produce.
Then flip the drum over and tune the batter head.
If you need to, get an Evan's "Torque key".
I use one...some people feel it's cheating, but anything that makes my life remotely easier is great to me!
Even with the Torque key, you may need to fine tune the drums by ear.
I used to like the bottom head tuned quite a bit higher than the batter, but the last time I tuned the kit, I tuned them all to the same tension using the Torque key set at 0(the lowest it will go), and the drumkit sounded incredible once I fine tuned it.
Tim
