J
JimiAlan
Guess I should direct this to you, Muttley. You seem to know this thing inside as well as outside after reading your replies....
Just picked a Tascam 688 Midistudio. I was told that everything worked and before I call the guy back I want to make sure I'm not doing something wrong. The unit powers on ok and I get a few lights and I can hear the motor start (under the transport). When I place a tape inside and push play, the heads do not come out to the tape. They remain in the RW/FW position. Is there some switch that I need to turn on to get these to move? Is there something that I'm missing? I have a 488MKII and when I press play on that I can here what sounds like a stepper motor pushing the heads towards the tape. I took the unit apart to see if it was just stuck or something and forced the heads out to the tape and did get sound out of it although the pinch roller never meets the capstan......and no, I did not get a manual with it....
HELP??!!
HELP??!!
