B
bluesboogieman
Hello.....can i plug a 4 ohm or 8 ohm speaker cabinet into a 2 ohm (super reverb) head without damaging the head or speakers? Thank you.
Doug
Doug
yes ..... and you actually don't run speakers into amps. You run amps into speakers so the real question is can you run an amp rated at 2 ohms into a 4 or 8 ohm cab.It's the other way around ya don't wanna do.![]()
Depends partly on how good your amp is. There is a very real threat from flyback voltage if the impedance mismatch is too great. Cheap amps can get zapped by it, good amps can mostly handle it.....but it's not worth the risk. I would never mismatch more than 1 level. I would mismatch a 4 ohm amp out to an 8 ohm speaker, but not to a 16 ohm speaker.
I have never seen an amp with a 2 ohm output. I don't understand why they would design it that way, other than to maximize power and current and minimize tube life. For one thing, you could never get a proper match with just one speaker, as nobody that I know of makes a 2 ohm speaker.
Interesting stuff about the power tube effect there. When I had one I wasn't paying much attention to how low that's running- and there's still that extension speaker jack. Presumably then that could lead to trouble easier than their other amps?All of the original Super Reverbs were 2 ohms. I'm sure there are others. They had 4-10" 8ohm speakers in parallel. One of the features about this particular amp was its obvious ability to get into power tube distortion at an early stage. One of the reasons so many Blues guys love these.
