O
		Olijanovi
I am currently in the midst of writing music for a theatre show.  A CD will be produced prior to the show.  Now what do i do?  Do I do everything in 44?  And then in 48?  I'll have to rerecord all the tracks?
.  If you're going to end up on a CD (which uses 44.1) - record at 44.1.  This is one of the few things in recording that really is as simple as that (in reality, that is....but nobody really even argues the theoretical differences in sampling rates anymore - because nobody can tell the difference....again...in reality)
I do a lot of musical theatre and work almost exclusively in 44.1 (because I back up my computer playback with CDs).
Unless there's something going on that you haven't explained then I don't see the need for 48.
Ok, well, unless the playback device is only capable of playing back music recorded at 48Khz, like an old ADAT machine or something, this doesn't make any sense. You said it was a computer with the sessions on it (which will play back 44.1 material just fine), sooooo again - you were told some nonsenseIt's a theatre production/musical. Obviously,for cost efficiency reasons we will use pre recorded material and the actors/singers will be singing over it. I was told that for that, I needed to be at a 48 sample rate.
.  There's a good reason to record everything at 44.1 (that being that you're ending up on a CD at some point), and no reason to record anything at 48, based on all that's been said here - stick with 44.1.Even if at the theatre they use a computer with the loaded sessions on it? They won't use a CD and the singers will sing live to it
Ok, at the next production meeting I'll try to get better answer. One thing I really don't want to do is to say: Hey! I was told that 48kh was bullcrap and I am doing everything in 44kh. Hehe
  ....  yeeeaaaa...  don't do that
.  They're probably using some old ADAT stuff or something that only works with 48Khz - all you can do is get them to clarify.  This post made me laugh out loud, though...literally
