andyhix
:dank:
Hey Dave (just guessing on who will answer this
Am I correct that I can't use the fx send (1 or 2) unless the track fader is at least partly on? I have a horribly dynamic vocal track that I would like to run through a compressor, via the fx loop, but to do so, it seems I need to mix in the dry original some. I can use the mixer sends on the back of the unit, but that leaves me with no EQing ability before the send, which is a bit of a bummer. Suggestions?
-Andy.
P.S. I have a half assed workaround using a 2nd mkii to send my tracks to, thus giving me EQ after the compressor, but it's still not my preference.
),Am I correct that I can't use the fx send (1 or 2) unless the track fader is at least partly on? I have a horribly dynamic vocal track that I would like to run through a compressor, via the fx loop, but to do so, it seems I need to mix in the dry original some. I can use the mixer sends on the back of the unit, but that leaves me with no EQing ability before the send, which is a bit of a bummer. Suggestions?
-Andy.
