I have been using direct recording (1-4) with pan set at 12 o'clock for each.
I had been mixing down with the tape cue mix/monitor out. I decided to start mixing down the "right" way with line out since the monitor mix doesn't allow post eq or panning (at least with Direct Recording).
When I try to mixdown with the line out (all tracks input set to TAPE), I only have audio coming out of the right output. Panning left of 12 removes the track from the mix instead of moving it left, and panning right boosts it in the right.
My question is, was I supposed to set the pan before recording and if so, how? The only panning tips the manual gives in relation to Direct Recording method is DR-ing one track (panned hard right) and using stereo left bus on the rest. Does direct recording make it automatically right channel only or do I have to pan hard left or something? Can I not do them all DR and have a stereo mixdown with line out?
If not and I have to use the stereo left/right bus....how do I know which record function to choose per track for my setup?
1-toms & cymb
2-strings & vox
3-kick
4-snare
Which would I set to L or R or direct input and how would I pan it?
In a nutshell I am having hard time understanding why the tape cue/monitor mix plays in both speakers fine while the line out mix doesn't. Thanks again for any tips and sorry if this is longwinded or confusing..
1-toms & cymb
2-strings & vox
3-kick
4-snare
