Scooter B
Member
Thanks to everyone who has helped with my questions on my 4 track (unbalanced) limitations and the mixer/patchbay wiring decisions.
After reading the 1402 manual completely it appears to me that there would be some flexiblity benifit in routing the mixer in my signal chain.
Two of wich are the ability to blend (premix) several mic or DI sources before going to one channel of tape (this is not ideal for mixing I know but I only have 4 tracks before bouncing) AND a bass roll off pad (wich none of my mic's have).
So the plan now is to use the mixer along with a Joe Meek VCQ6 and DMP3 pre and an unbalanced patch bay.
When routing through the mixer my plan was to:
Mic/DI > mixer input > mixer out > 4 track using channel inserts for compressors and Aux sends to patchbay for effects.
The Mackie hook up manuel shows a different 4-track scheme you can see here at http://www.mackie.com/record/pdf/vlzproseries_hu.pdf
(and SKIP TO PAGE 4) but basically they recomend this:
Mic/DI inputs > mixer channels 1-4 > channel inserts > 4-track > back to mixer channels 5,7,9,11 (6,8,10 &12 are Stereo Right inputs) and the Aux sends and returns would be used the same.
As the Mackie manual was well written and seems well thought out to use multiple options I am assuming there are some benefits to using their somewhat more complicated wiring scheme...
Q1 What advantages are there with this?
Q2 How do I fit the compressors into this set up? I am guessing;
Mic/DI > Preamp > Comp before the mixer input as the inserts are being sent to the 4-track.
Thanks
Thanks
