Hello everyone, I recently bought a Tascam 388 in pretty nice condition, First of all I know little about the technically end of recording and would very much appreciate any help...
The seller stated the heads are in good condition, however I have no way of knowing as I don't know what to look for in determining this. I've done some basic test recordings and it seems to produce pretty good quality so far, nothing unusual, but then again I don't have anything to compare it to.
OK, here's some things I'm concerned about...
I was thinking about getting it serviced locally at an authorized Tascam repair shop, just to have them check the whole thing out, but at a minimum charge of $200 (and a max of who knows) I'm not sure I should as it seems to work fine. There is however a short on track one, where by you must tap near the fader area in order to get a signal sometimes. Is this something I should try and fix myself?
The previous owner was using 457 1.5-mil 1200ft tape but the manual calls for 456 1-mil 1800ft tape. I've been told that the heads need to be realigned for different thickness tape, but the original owner says both 456 and 457 work with no adjustments needed. Is this correct and if not can I make any adjustments myself?
What's the difference between realigning the heads and calibrating the heads? and again can I do it myself? I was told you need to realign the heads every four hours???? can this be?
Also, are parts such as heads still available for this reelect? If so what do they sell for?
Thank you for any and all responses.
Ed
Ed
