24 bit in and around, 16 bit out?
  • Thread starter Thread starter jedblue
For the second question, no, 44.1khz sample rate will most definitely not reproduce a complex 20khz waveform because that's not what the specification means. The specification for audio normally refers to sinewaves, at least for the upper limit.That applied long before digital came along.
So an analog piece of gear that is specified to be flat from 20hz to 20khz is only flat for sinewaves. Sure, it will handle complex waveforms but only up to the equivalent of a 20khz sinewave. A complex 20khz waveform is simply out of the specified range.
Respectfully, Tim, this is just the kind of misunderstanding/mis-explanation that makes this subject so dicey. What you're saying is kind of right, but it's equally kinda wrong in a couple of important ways.
Any single frequency tone can *only* be a sine wave. There is no such thing as a complex wave at 20kHz (or any other frequency, FTM.) If you're looking at a 20kHz wave that's complex or irregular in that it has bumps in it, those bumps, by definition, are at higher frequencies, and the mix of frequencies is what creates the complex waveform. But it's NOT a "complex 20kHz waveform"; it's not a distortion at/of 20KkHz. So, yes, if you're looking at the wave the distortions on it may not be reproduced, but all that means is that frequencies above 20k will not be reproduced, which we already know. But the actual 20k content will remain untouched.
Other "simple" geometric waveforms such as sawtooth waves, square waves, etc. are not pure frequencies, they are compound signals built from sine waves of greater frequencies, and simply repeat their pattern of higher frequency wave combinations at the observed frequency. This is why George's sawtooths (and almost all real sawtooths) look awful and why aliasing is so difficult to avoid in soft synths at lower sample rates, because they require higher frequencies to generate. By definition, a "20k sawtooth" is not a bandwidth-limited signal limited at 20k.
But, except in George's lab, in music and real life one is virtually never going to find 20kHz sawtooths or square waves (sawtooths and squares are hard enough to find at *any* frequency, except in synths), simply because they would require so much in the way of constituent ultrasonic and hypersonic wavelets to create, and Mom Nature just is not into that bag. And as George said, if you have sounds with fundamentals above 10k or certainly 15k, such as a 10 or 15k sawtooth, you've got more problems than Nyquist to worry about ;).
And yes, the Nyquist theory *does* state that it will reproduce 20k *exactly* as long as the entirety of the signal is of limited bandwidth. Excluding physical limitations in actually implementing the theory in physical components, the theory proves that doubling the sample rate of the highest frequency in a limited bandwidth signal will reproduce that signal with no information loss. "With no information loss" is IT-speak for what we in the audio world call lossless, it means 100% accuracy.
Where we have the biggest problems in physically implementing the theory is in actually limiting the signal bandwidth and in the accuracy of the sample timing. In today's technology and business market, quality bandwidth limiting and sample clocking are not ubiquitous. This is what introduces the HF errors (some more audible, some less so) we actually get from our converters, not any inaccuracies in Nyquist itself.
G.
To echo Glen's points about difficulty with/lack of understanding all this digital mess is because the ones that truly understand how digitizing and analog reconstruction works are the people who are not musicians.
And to echo-echo even further... :) …you can pull up ANY audio magazine (Mix, EQ, Tape Op, EM, etc)...and I guarantee you will find most articles/interviews where the interviewees (I'm going to assume they are "pros" since the magazine decided to interview them) are almost always talking about using the higher sampling rates and deeper bits. I have yet to see one point-blank say they are not….though they may be saying one thing for the interview and doing something different in the studio???
That’s why I asked in the other thread not too long ago…how many here really ARE recording at 16/44.1 (Ethan doesn’t count ;) )…?
Not to mention that most every advertisement in every magazine for new digital gear uses those same "higher rez" points to sell their new products.
So yeah...most musicians ARE going to lean toward what "pros" are saying (like I said, we can't all conduct our own in-depth experiments).
I think those are reasons why these questions/discussions keep coming up…that higher-rez mentality is what is being actively promoted and sold. It’s been going on for the last 10 years now.
Yep. It's all a big marketing thing, sold by people who have no clue to people that have no clue.
BTW, being a "pro audio engineer" is no more a guarantee that they know what's going on than being a "pro" anything in any line of work is. The 80/20 rule; only 20% of people in any line of work would score an 80% or better on a job competence test. And when it comes to stuff like sample rates, I'd bet that only 20% of that 20% truly understand what's really happening in their boxes and in their heads.
You gotta get your head out of magazines and into text books (and I mean text books, not the stuff you find in the music aisle at Borders), out of the Internet and into the studio if you really want to know what's going on with this stuff. The opinions of other lemmings will only take you off the cliff.
G.
G.
Glen, I agree. I think the difference is that I was prepared to run with the term "complex waveform", at least for the purposes of the discussion since that was the term the guy used, and show, as you have repeated here, that such a waveform contains higher frequencies which are out of the passband.
Cheers Tim
What you are refering to are waveforms who's FUNDAMENTAL frequency is at 20kHz. Yes, by definition you cannot accurately reproduce a complex waveform who's fundamental frequency is 20kHz. Also, by definition you can't HEAR complex waveform who's fundamental frequency is at 20kHz EVEN IF YOU COULD REPRODUCE IT.
This is because complex waveforms consist of not only the fundamental frequency but also contain higher frequency content. If you can't hear this higher frequency content then who cares about reproducing it anyway?
Think about this. If we are talking about a pitched, complex waveform at 20kHz, then the first partial is going to be at 40kHz, second is going to be at 60kHz, so on and so forth...
Can you hear 40kHz, much less 60?
Plus, can anyone tell me if there is something in nature (on earth) that can produce waves with fundamental frequency of 20kHz? This is very easy to synthesize, but to produce acoustically? Just wondering.
...out of the Internet and into the studio...
Yeah...for sure! :D
I guess that's why I haven't bothered to reexamine the whole bit/sample rate discussions a few years now…until a couple of them popped up here.
I didn’t see anything specifically *wrong* with using 24/88.2 for bringing stuff into the DAW other than the larger file sizes…and CPU overload was never an issue since I rarely used a lot of ITB plugs/processing…I’m just editing/comping for the most part.
Like we talked about in the sample rate discussions…I may do some simple blindfold tests just to see how my own converters sound at 24/44.1 VS 24/88.2…but when I picked 24/88.2, that was about 7-8 years ago when the debates were ragging and it got tedious trying to sift through all the science!
I just wanted to get on with the recording and not worry so much all that…so I picked my settings and left them that way.
But even with my array of hard drives (internal/external) by the time I go to doing a half-dozen stereo mixes per/song…the HD space was becoming tight…so if 44.1 sounds as good (or better) on my converters, I may ratchet down from 88.2 starting with my next project.
AFA the bit rate…my converters are fixed at 24 (no option for 16) and my DAW runs at 32float…so it’s kinda academic unless I spring for new converters, but 24 channels of some better quality A/D/A would not be cheap…so again, it’s academic at this point in time.
Forgetting all the math…like I said, I don’t see anything specifically *wrong* even staying with the 24/88. if my ears tell me to do that.
I agree…it’s really not THAT important in the day-to-day studio process.
If your ears tell you to - after all the dust has settled and you're listening to your 44.1 masters on CD that the ones captured and/or mixed in 88.2 sound better to you - then absolutely, run with it!
As far as the "wrong" thing, the question IMHO is not whether something is "wrong" but whether it's "right". There's an infinite world out there of things that may not technically or ethically (depending on the subject) be wrong, but they are not necessarily technically or ethically right either.
Let's say, just for the "last round" of beers here ;), that your ears don't really hear an advantage (not just a difference, but an *advantage*; not all differences are necessarily improvements), or are unsure if there really is an advantage or not. Then what's "right" about selecting the more costly option? Costly not necessarily in terms of cash money, but costly in amount of resources used and in extra work required. If the advantage is not there or dubious, is it really worth going through the extra sample rate conversions in mastering and the extra disc space and CPU cycles? Even if you have a computer with the capacity to handle it without sweating, that only makes it less wrong, it doesn't make it right.
Granted we're talking esoterics here, because we're only talking marginal extra work for you and a capable computer. I get that. But really, as you have already agreed, everything about this subject is dealing with esoterics and marginal issues, so relative to the weight of the subject in general, the weight of those issues is proportional, and therefore reasonable to consider, at least for as far as this subject is worth considering :).
G.
Oh I agree...it's going to have to be a noticeable *better* difference and logical advantage.
It is possible that I've been using 88.2 with no real benefit...but like I said, at the time, I just wanted to get on with the actual recording process having set up my new DAW, and there was way too much debating still going on...so yeah, "bigger" seemed like the safer choice at the time.
I've had quite a few 16/44.1 files in my DAW (I can work with them fine, any bit/rate...it's just for capturing that the converters only use 24 bits)...and I never thought "They sound crappy."...but I never did any real focused comparisons of the same file at different SRs in my system.
Even though my current drive space covers my needs for most stuff, I was wondering about the 24/44.1 format even before these threads popped up, just for the sake of efficiency...but I've been using 24/88.2 for a long time now...so that's why I'm questioning things and turning over every stone before making any changes to my SOP.
For this type of stuff...I wanna set-n-forget and not have to reevaluate what I am using over and over...if you know what mean! :D
I do :). About all I can say about that is what we said a loooong time ago in the other thread: Because diffrent converters have different personalities, take an afternoon to set up a couple of A/B tests with a couple of different music styles to see how it works out for you. best if you have a friend/partner set it up the tests from the start to avoid any unintentional bias on your part (we're all human! ;) ). if that's not possible, set up te test yourself, but wait until the next day to actually do the listening test to keep your ear's bias down. Give the files ambiguous/anonymous names and have a friend play them for you; this will ensure double-blindness in the test. You'll know which ones A and B are after the test is over, but he won't as he's actually selecting them.
Then go with what you prefer, set, and forget until you change converters :).
With the Noisewreck Exception that the rules can change when using VSTis, those would require their own sparate tests if you wanted to nail it down that tight.
G.
Well, cymbals and violins etc have harmonics that go way beyond 20 KHz, but that's not the same as a fundamental that high. I'm sure something small enough could start at 20 KHz. Like a dog whistle, or a really tiny violin. :D
--Ethan
--Ethan
Yeah, I know there are some sources that have harmonics that go beyond 100kHz, but like you say, having sources who's fundamental is high up around 20kHz or so is probably hard to find. Maybe an electron wiggles around that, but then again we can't hear the sound of a single electron :D
Related, last night I watched a science channel type show and they showed bats generating ultrasonic frequencies. People can't hear the sound of course, so they had a frequency converter that down-shifted the sound into the audible (by humans) range.
So there's a source that occurs in nature where the fundamental frequencies are above 20 KHz.
--Ethan
Isn't that an old Zen koan? What is the sound of one electron clapping? ;)
There's also lightning strikes, whales, a wind blowing through a hole of the right size (like a natural dog whistle) and many electric motors. Plus there a lot of VLF sources such as earthquakes, atmostpheric soliton waves, and any '77 Chevy Monte Carlo with 26" rims.
G.
Jeez! :mad: (smacks head)
All this time...? that's the problem with my bat tracks?!
--Ethan
Something missing when we discuss sound is how humans detect it beyond hearing. We all know the 20 - 20 kHz hearing range (hopefully), but I don't see much analysis about our sense of feel in the perception of music. We know of course that we feel infrasonic sound, though the ear cannot “hear” it. These bass frequencies rattle our bones, so to speak. What's the impact, if any, of ultrasonic frequencies on our bones I wonder?
I don’t have any idea myself. I’ve always been agnostic when it comes to frequencies above human hearing. That’s not the reason I go with higher resolution and higher sampling rates… or analog. Everything we discuss concerns audibility. What about feelability of these high frequencies?
Any thoughts?
~Tim
