M
mixsit
I've done it two or three times (last night for cryin out loud!) adjusting the wrong thing in this case, or something in 'bypass-- Each time I would swear 'heard it.ha. I hate when I do that.
Did you ever make a mix that sounds great, only to have it sound like crap the next day? Did you ever hear someone else's commercial mix sound amazing, only to have it sound not so amazing on a different day? Did you ever tweak a snare EQ to perfection only to discover later you were actually adjusting the EQ on a muted BG vocal track?
--Ethan
But - as I understand it - when you go to record this situation, something different happens. If that sound is captured (and preamped) at a level lower than the composite analog noise level of the downstream chain, the analog noise will in effect mask the lower level stuff because it will get buried in the circuit noise itself. By the time it gets to digital, it's too late, all the digital will do is more or less faithfully reproduce the analog noise.
That's the key here isn't it?However, many VSTi Synths now generate 32-bit audio directly.
That makes sense to me if you could hear unprocessed digits but don't you have noise on the way out too?(D/A)That's the key here isn't it?
See, most people on this board think from the prespective of using the computer as a sort of tape recorder, where you capture some external sources. Many forget that with the computer you can generate the sounds within the computer itself, thus avoiding the room noise, mic noise, preamp noise, line-in noise and all that stuff.
As I demonstrated in an earlier thread, when you are dealing with sound sources that have been generated INSIDE THE COMPUTER, then higher bit depths AND sample rates make a vast difference.
Absolutely. That's one of the basic hearing bias' that an engineer should learn to recognize and account for during critical listening.A long time ago I read that if you play two recordings to a person and the only difference was that one was slightly louder than the other that the listener would almost always say the louder one sounded better.
It must be human nature that louder is better.
Hearing unprocessed digits is not the pointThat makes sense to me if you could hear unprocessed digits but don't you have noise on the way out too?(D/A)
I'd be interested to read that thread. Can you give us a link?
Cheers,
Otto
Thing is...we DO hear all those sounds oustide of the "conscious" human hearing range, our ears don't shut down at 22kHz...
...we may be processing those sounds differently......
I know the majority of debates about "16bit VS 24bit" and "44.1 VS anything higher" all center on human hearing and what we can hear concsiously...and there is an impliead assumption by the "lower-is-good-enough" crowd that if we can't hear it conscioulsy, then it's not imporant.
Just to toss another fly into the ointment...
Vast difference? Not likely. But tell you what. Please post a 10-second render of some music at 32 bits, then I'll download and convert it to 16 bits without even using dither. I'll post the results here, and everyone can tell us if they hear a "vast" difference. Deal?
--Ethan
Yeah, I actually wonder more about the impact of the bandwidth limiting than the issue of resolution and number of bits. What I wonder about is whether a properly bandwidth limited signal for a 44.1K sample rate undermines the accuracy of some phase information that our ears can detect in the location of sound. I need to reread Streicher's book on stereo sound and see if he has any good references on the issue.
Cheers,
Otto
Didn't know which thread to post this inDid you listen to the examples? If you can't hear the differences in the examples in that post, then your ears are made of wood.
