Drummerbones
I've got KRK Rokit 8's along with the KRK 10" subwoofer as my primary monitors. What I'm wanting to do is utilize a second set of monitors, fairly cheap, so I get a good idea what my mixes sound like on your run-of-the-mill cheapo commercial speakers. I recently purchased an active pair of Edirols...they certainly do the trick! Ask for somewhat crappy monitors and though shalt receive...kind of ironic that I purposely bought these things. Anyway, they're serving their purpose as mentioned above, but I'm wanting to try to patch them into my existing subwoofer.
I have a SM Pro M-Patch that allows me to select between each speaker set, but I haven't quite figured out the sub thing. The easiest thing would be to hook up a separate sub for the Edirols and move on. I did try this approach with some hicups:
I'm running the mast audio from my soundcard directly into the KRK sub, then running the sub output to the M-Patch. I then am running the signal to each set of monitors which allows me to use the KRK sub with both sets of monitors. HOWEVER, this does not allow me to increase the sub volume along with the selected speakers. Since the sub is the main input, it's volume is independent of the volume control on the M-Patch.
I thought I had the solution but not quite. Aside from buying a cheap sub to go along with Edirols and calling it good, any ideas on what options I might have. Sorry for the long post. Thanks in advance for your input.
Bones
Bones
