Thanx. Not sure about "mostly". Lol. A buddy of mine has the ASAT. Basic solid body with some optional pickup choices. The ASAT Deluxe was the thinline.
Now that is absolutely correct. IT confused me too because there were in fact two models.
FWIW: I've been retired for a while now. In one life, I worked in electronic engineering 30 years in R&D. I know a few things about capacitors. I could rattle off, just from the top of my head, 10 different capacitor materials. From ceramic to paper/oil BBs. At the end of the day, a capacitor has one function: to store an electrical charge. How fast a capacitor charges, and discharges is a function of the input current, and the discharge resistance (which is usually ground). That's why a cap, in a tone control circuit, is "fed" from a pot and the other end is at ground. You all know this.
Whether a cap is a cheap 1 penny ceramic, or a 100$ BB, the only IMPORTANT spec is the
tolerance. Cheap caps can have a tolerance of +/- 20%. When you start moving up in grades/materials/cost the tolerance gets tighter.
Lile any other electronic component, after production, they are tested, and then "binned" based on the test results. The bins could be +/- 1%. 2%, 5%,, .... The tighter the tolerance, the more $$$.
If you have an Orange Drop that is .022uF that is within 1%, and a BB that is .022uF that is within 1%, or a polystyrene .022uF within 1%, I would bet 2$ to a donut that NO ONE would be able to tell any of them apart. Thought the cost can be 1$ for 1, 100$ for another. It's the actual capacitance that matters. Better materials last longer, stand up better with use, and are generally better. But spending 100$ for a .022uF cap is beyond my sensibilities.
When designing circuits, cost is ALWAYS an issue. But there are some components that you don't want to skimp on. BUT, there is always a cheaper alternative, that will be just as effective in the long run.
"Spend your pennies wisely" I was once told. Put you money where it does the most good. Using a 100$ capacitor would have put me on the wall of shame, if not fired.
