NEOKLON - modern take on the Klon (demo/review)
  • Thread starter Thread starter BDJohnston
B
BDJohnston
Active member
The myth and scarcity of an original Klon has made it legend in the gear industry. I don’t get it… since it’s a particular flavor of drive, but has sold in recent times for upward of $5,000 USD… but that’s how musicians operate. Some are willing to pay $100k for a ’59 Les Paul that sold for $450 with a case in 1959. I get nostalgia, but would sooner have a drive that has similar tonal characteristics that have been improved upon – and for a fraction of the price.
Jim Hagerman admits that he doesn’t play much guitar besides some noodling around, but he knows electronics and sound (with electronics that delve into the high-end audiophonics industry). What he did to the Klon circuit should have people turning their heads away from the original and its clones and toward NEOKLØN.
One thing you will notice and hear with NEOKLØN, is the increased headroom. Gone is the compressed signal, which means improved picking and sound dynamics; the notes sound livelier and fuller. Now, I never played through an original Klon, but I did play through a few clones that kept as true as possible to the original circuit. Further, in that regard, I can say that NEOKLØN has an exceptional low noise floor. With both Gain and Level up full, there is a low ‘sshhhh’ sound; barely audible with complete silence and no playing.
As for the sound, there is a robustness or thickness, without being too grainy, yet it does not have that thin digital quality some overdrives possess. The best way to describe it, is that it makes the tone beefier, while bringing forward those added harmonics and details. NEOKLØN does make the base tone a touch darker sounding, rectified easily enough with the pedal’s Tone control. But whether playing a touch dirty or making your high-gain amp sound thicker and better, NEOKLØN certainly sounds different than usual overdrives or Klon clones.
NEOKLØN has gone to the next level, as Jim Hagerman revamped the circuit to retain the original characteristics, but improved upon the response at low gain. No, this is not an improved and new ‘Coke,’ in that it’s a completely different product. Rather, Jim removed the flat bandwidth response at minimum gain; and in effect, this allows for the full tonal response at low Gain levels. In fact, NEOKLØN reminds me of a Tube Screamer, in that it is highly useful with its Gain all the way down! With NEOKLØN’s Gain completely down, it produces a similar tonal response to the original Klon and with its gain around 9-10 o’clock. Generally, and with a crunch/dirty amp, I don’t have NEOKLØN’s gain past 9-o’clock (and often all the way down), and may have it around 12-noon or slightly higher for lead (although all the way down sounds good still).
NEOKLØN currently comes as a kit, which takes five-minutes to assemble. The circuit board is fully assembled and tested, and so it’s not a full build kit that requires soldering. It also requires a measly 20mA power, ideal for any pedalboard. If you’re a Klon fan, then this modern take is a must.
JHS has a similar deal with the Notaklon. $100 and it is only sold as a kit that doesn't need soldering. JHS stayed closer to the original Klon in terms of sound.
Therein lies the issue, which should have been clear from my demo and review... JHS did one that is more true to the original. That is NOT the point of the NEOKLON, which was to provide a better sonic response on low gain (0 to 9-o'clock), something you don't get with the original. That is why the NEOKLON can have the gain turned all the way down and it sounds great, and something you cannot get from the original. Thereafter, it is true to the original circuit, as pointed out in the demo. If someone wants something similar to the original, then that's fine, but if someone wants something more? Also JHS will be doing a show on the TUBEKLON, which is the tube version of the NEOKLON. Must be pretty good for that channel to feature it.
There are at least a couple of dozen "improvced" Klons. I really don't get excited about another one. I really don't get excited about another cloned Klon, other than the fact that you can get essentially the same thing without paying the stupid money that the originals go for.
It is good to see pedals going for $100 bucks, tho, for a little box with $20 worth of parts iniside.
Maybe you can spend the time researching, changing specs, etc., doing several builds trying to get it right, and then charge $10. That should help you retire. FYI... there is information in the video that shows how it's improved... I already spoke about it (and that particular feature is not found in the original), and since it was custom-designed by Hagerman, it will not sound like other Klon reproductions. But whatever... you don't have to buy it.
Call me jaded, but I have watched and read so many reviews and comparisons of the lastest and greatest pedal that it's gotten almost ridiculous. The pedal comparisons go one of two directions... they compare NewGuy to Original, and it doesn't sound exactly the same, so it's crap, or NewGuy sounds different from Original and they think it outshines the original by a mile.
Musicians Friend list 367 overdrive/distortion pedals. Klon clones, TS clones, Muff clones, RAT clones, OD9 clones. $40 to $400. I have two on my board, a Soul Food and a TS9. They have been on there for years. There's a Route 66 v2 upstairs. If I can't get a sound I like from those, it's not the pedal's fault. Most of the time, a simple TS9 is all that's needed to crank up a simple Fender clean Princeton Reverb.
If I was into designing pedals, it would be for fun, not for retirement. (heck, I'm 6 years into that already...)
I can't speak for any other product or review, but it's an IMPROVED UPON version due to the initial gain section. That's it. Many people want a Klon (good for them, who cares?), and if so, then this one has better response in the first quarter, while retaining the same characteristics of the rest of the gain range. Now, if YOU don't want to buy it, and stick with your older gear, then perfect... you found what works for you. But maybe we all should ignore every other pedal, buy what you have, and then avoid any purchases in the future. We all can have TS9 and Soul Food pedal boards. Sounds like fun.
