rob aylestone
Moderator
Three interfaces arrived -£16, £17 and £22 including getting to me from china.
If you saw the cheap U87 topic and the dreadful results, you won't be too expectant in the quality stakes.
One of them was simply crazy - an interface designed for podcasting, with built in sound effects and buttons labelled male, female and baby! Clearly it does it by changing the sample rate so the DAW or streaming device gets a new pitch. The trouble is that the sample rate seems to be extremely variable and goes up and down on it's own. I tried to edit my usual way - drag in the video and the audio and simply align a clap I usually use for sync. This worked but within a single sentence, it was a second adrift - At first I figured a sample rate mismatch? Had it recorded at 44.1 then gone to 48 etc? No - it went up and down up to nearly a whole note away. In the end after trying everything - even stretching and shrinking in Cubase, I just chopped it into sentences and synced manually the first bit of every sentence. What a process!
Two of the interfaces had 48V and two XLRs with combo connection for guitars. Sadly the best one had a dodgy socket.
I'm going back to proper products now - I've had my fun with the cheap rubbish I managed to find.
