TalismanRich
Smithers, DCC and MiniDisc both used data compression to get enough music on their small formats. It's a bit like MP3 vs Wave. If Geezer Butler is wailing away on his bass, it's going to make you perceive less of the more subtle high frequencies of his hi-hat and cymbals. So, when the encoders look at the signal, it might drop out a good chunk of the highs since they are masked. If you look at MP3 files, at 128k, there's not anything above about 16K. At 320k, it will extend out to 20kHz.
I have heard the differences between 128k MP3 and the original wave file, but at by the time I got to about 224k, I ccouldn't distinguish any difference. This was some years back, and by now my hearing is much worse, so I would probably not be able to hear the difference today. Even then, it was relatively minor.
I do remember when I got my first MP3 player, and since CF cards were pretty small back then, I did a bunch of albums at 64kbs. On any half decent stereo, you could clearly hear the difference. I tried both MP3 and WMA. Both were bad. I bumped things up to 96k as a compromise between getting enough music on a 32MB CF card and acceptable quality.
It's the same as using JPEG for pictures. Take a photo at 10MP, and convert it to JPEG. Then start zooming in, and you'll start to see the difference in quality, as more and more information is dropped. You lose sharpness of edges, and fine details like hair will be "smoothed" into an indistinguishable mass. Do the process 2 or 3 times and you really see a difference. If you just load and save a BMP file, it will always be the same. The tradeoff is having a 36MB file vs a 2MB file.
