T
		Tempo Fugitive
Hello, I'm wondering if any one can help me with an issue I'm having after Mastering a track.
I'm using Reason 11 as my DAW. I have the Limiter6 plugin for brickwall limiting (with ISP Protection on---set to Precise).
At the end of my mastering chain, I have the Youlean Loudness Meter. It tells me my True Peaks are at -0.9 db throughout.
I export the song to Audio (i.e. 16 bit .wav file with dithering & 44.1k sample rate).
Then I open a new instance of Reason and import the newly mastered .wav file in. I put the Youlean Loudness Meter on the master effect chain (and nothing else), and it reads True Peaks in the +2db to +3db range!
I don't understand how this can be happening?
I posted this question on a Reason specific forum, and I was told that Reason is bad for mastering (with the only explanation being that you cannot trust its built-in metering, but I'm not using any of its metering----I'm using Youlean Loudness Meter).
So I guess I'm not sure what I should do.
Does anyone have experience dealing with this type of problem?
Could it be that Limiter6 (free version) is not a good Limiter?
Or could it be that Reason is in fact a bad DAW for mastering?
Sorry if that was a long read, but any help would be appreciated! TIA!
