			maartenl945
Member
Hi,
I made a video about this but wonder where you all stand ?
Regards,
Maarten
Regards,
Maarten
			The mix is so much cleaner that way.Except live, where I high pass everything but bass, kick drum, piano (sometimes), Hammond organ etc.
			Well, I haven't clicked the OP's link.Click bait
			Yes it's contentious and was wondering about how other do it. Thanks for your input.Yes, my thoughts too - for live it really helps, but for recording where people listen properly, robbing voices of their fundamentals is wrong in most cases, and while kick and bass can overlap, one is wide band and one isn't so if you get clashes and that is if not a certainty. then I'd probably scoop a little of the kick fundamental or 1st harmonic out of the bass, but I certainly would not remove anything. Little point in a low B string, if you filter it off! Even if we talk PA - then bass guitar and kick drum always co-exist.
There will be cases where the bass content of some sources is less important - I can live with thinning these out, but to do it to piano, organs, bass and other low instruments is taking quite a bit of the source away. My experience is that musicians will soon spot this. Bass is a bit thin, or where's my left hand gone? Those sorts of comments.
In fact - I just hate rules and rarely have any that I implement before engaging my ears. Use high pass if there is a problem by all means, but to lose all the bottom end from many sources is a strange rule to have. I have also never heard a voice made better by filtering off the bottom end - apart from on bass baritones when the sounds isn't really singing but almost an effect.
			Aaah go on ... do itWell, I haven't clicked the OP's link.
			This being an audio forum, I think people might be interested and have opinions on this.Click bait
			Thanks for that. So far, the majority over here seems to be more cautious with low cuts. Quite interesting how this differs from some other forums where I’ve asked the same question. I guess we all have our own way to achieve what we want in a mix. Many ways to Rome .... ?.I almost never high pass anything. The only reason I would is if I perceive a problem, like useless rumble or the singer tapping his foot on the leg of the mix stand.
I have never run into the problem of kick and bass fighting, but my bass sounds tend to be very compressed and have a decent amount of midrange for clarity.
