6
682
Member
I record into an interface usually with 2 mics in stereo. I put a pick up on the acoustic guitar and went direct in.
It sounded good thru headphones with the HiZ button on.That setup will be just for acoustic guitar with heavy fx.
I forgot to remove the other mic from the interface and noticed it was still active. Is there any problem with having both inputs going at one time like that??...the one direct with HiZ and the other balanced mic input..?
If I record in Garageband will it show up as 2 separate tracks?? Or is it better to leave the mics out when I use the direct
plug...?
The interface has 2 other unbalanced plugs on the back but I dont use them..
What do you think..?
plug...?
