S
		Siydock
Or can you just use the mastering bus in the mix?
			There is nothing to master with one song. That is nonsense.
Depends what you call mastering.
Louder is not better.
The new LUFS standard wont let you stand out. They will push yours back down to the same level only it wont sound as good as the others.
Mastering a single song is NONSENSE.
True mastering, not making things louder, takes a set of songs and puts them together in the best sequence while keeping ALL their levels at compatible loudness.
That is technically PREmastering, as there is the traditional true mastering for the media whether vinyl LP, tape, radio, whatever.
Read about LUFS. Your goal of standing out by being louder has been killed. You now need to make it better not louder.
As it happens, I am always mastering singles. They are usually tracks that are later to become a set for a CD, but I am working on them and want to get a feel for how they will finally sound. And I nearly always do make them louder. That's because when I'm working on a mix I leave scads of headroom. But, as Miro notes, making them louder is only part of the whole process.
 and
 were for.
But....louder is not better!![]()
The loudness war started as a pissing match between different artists and labels. I don't think the wannabees and amateurs knew what hit them.So true. But many wannabees and amateurs think so. That is how the loudness war got started.
I'd almost take offense. I've been doing this for over 25 years and was the studio liaison for mastering sessions for years before that. Mastering is and has always been the creation of the master. The definition is *in* the word. Back in the day, it was lathes and vacuums, it turned into premastering for compact disc (I still use the term) on PMCD or Exabyte (I still have the drive) and now on many occasions, it's simply exporting a digital single.Depends what you call mastering.
You are in the biz of selling 'mastering' so I would expect you to have the more current viewpoint of it versus what it really is and was for decades before the term got misused so much that the meaning changed.
but....louder is not better!:d
Ironically, I'm typing this after actually creating to CD-R premasters for the 2nd time in a month. It's so rare now thanks to end-user DDP loadback that I'm using CD-R stock that's probably two years old (and I still use Plextor 7xx drives and confirm BLER with PlexTools Pro).
The "current view" is that clients want to release the best possible version of their recordings. That's one thing that hasn't changed at all. It's certainly changed the way things work -- I used to get [a bunch of] recordings and created a premaster from that.
Then things got cheap (vinyl cutting was still $$$ and even a single quality CD-R was $75 - each). And "wannabees and amateurs" had access to digital maul-the-band compression via the Finalizer and what not.
Now (pretty frequently), I get [a track or two] a month ahead of the rest of the mixes. Radio push, online, video shoots, whatever. If they want those processed (a.k.a. "mastered" as they refer to it), what do you want me to do? I mean, I could correct their grammar (which technically, I already do) or I could just do what they want. Which is what they want. I'd rather do what they want.
As far as "loudness" - I've been anti-loudness war since the loudness war started. But again - to some extent, you have to give the client what they want. Sometimes, the job is doing that while having as little negative impact as possible. Which is a challenge in itself.
I am knowledgeable and often attacked by ignorant weenies.
