CoolCat
give me some ideas...
But impedance is almost never just one number. It is frequency dependent. The DIs are probably pretty close to flat over out frequencies of interest, but the pickup has a large inductive component which means the impedance gets big fast as the frequency goes up. That humbuckers might be 15K resistance at DC, but the impedance at 5KHz is 125KOhms! Even a 1M input doesn't quite get us to 10:1, but...10:1 is about the minimum ratio you would want. Bad things happen below that. Consider a pickup with a relatively high output of say 15 K-Ohms (maybe a Gibson humbucker or something) connected to an amp with an input of 1 M-Ohms. This gives you a lot more than 10:1, and it's not a problem. The same pickup going into the passive JDI might start to give you some unwanted artifacts, whereas the J48 still maintains the 10:1 minimum.
ashcat_lt said:Now, a passive DI doesn't have much impedance of its own in either direction. What it does is "reflect" the impedance of whatever is attached to it. In practice, that means that the effective impedance is some multiple of the device at the other end. What you multiply by depends on the turn ratio. In a typical DI this factor should be around 130. So, the InZ (the load the bass sees) will 130x the impedance of the mic pre you plug it into. That will very often be like 1.5K, which comes out a little bigger than the JDI you cited, but still not big enough for my tastes. To be fair, though, I think a lot of people like these because of the way they shave off the very top edge of typical instruments. 15K is not typical by any means. 3K-8K is more realistic for most people.
The one thing I started doing is putting foam on the strings and really like that dead sound. I read about somewhere on the board, looked at a couple of links, but I really dig the sound it gives. Sometime I take out the foam, but not often. Maybe it covers up my less than stellar playing. But it is different and noticeable.
