S
The faster way is not to post in multiple forums.
That's definitely the slower way.
Welcome to HR, none the less.![]()
I totally agree.. I was recording and mixing before the age of digital, let alone D.A.W. ... My best advice has always been K.I.S.S. As in 'Keep It Simple...'.I was recording before we used DAWs and so I have done both. Now everybody is an engineer. Well fine, but at least try to understand your ears matter much more than your eyes.
Boy that's a good one! Can I use it?My best advice has always been K.I.S.S. As in 'Keep It Simple...'.
" Is there a faster way to level out vocals? "
yes there is. You track with a compressor in the signal chain and use the compressor as a limiter. That a way, the converter is capturing a usable signal and less time is needed in the Daw for final touches on the track. When someone tracks with too much dynamic range, the signal to noise of the converter can work against it, and reduction of the dynamic range inside the daw with a plugin will have a tendency to raise the noise floor and lower its high frequency response (mainly because of the amount of dynamic range reduction needed)
Great advice for someone working with 12 bit gear or noisy preamps.
