R
Robus
Nah, not going to try to start another 'nother thread. This is it. It would be great if we could change the title of this one, or if a mod could do that.
The narrow EQ notches in midrange of the heavy guitars, that was reducing harshness?
The lead guitar is more abrasive, but is pretty low in the mix.
That tells me your master bus plugins aren't the trouble, if indeed there is trouble.
When I turn the volume up, it's definitely those pointy midrange frequencies that make me want to turn down again.
Is anybody else telling you the mix is harsh? Do you think it is?
I'm not skilled at identifying frequencies by ear, but would guess what I'm hearing is in the 1500-2000 range.
I did hear something interesting. It's in the chorus and the heavy parts of the song. Do you hear it? What is that? It wasn't there in any of my songs that tested for comparison.
It's got to be a cymbal. It's pretty strong across the whole range from below 2000 almost to 6000. It seems most intense in the lower 2000s. Like having a jet engine going in the background. Might be what is jumping out at me as I crank it up.
Listen, if it's cymbals then it is what it is. We've established that we have different taste in cymbals, so I'm not the one to judge.
I wonder if we are really hearing the same things. You monitor in headphones. I only use speakers. It really does make a difference. That glitch that you heard so clearly on my last song, I only noticed it when I put on headphones.
Guitar Tone is Tone. I'm waiting to hear some tone : )
I don't have a whole lot, but I do have tone : )
Both the guitars and cymbals are pretty active in the 2.5khz range. I already do a guitar cut there, but let me look at the cymbals too. I don't think I EQ the cymbals in that area. I'll check it out. It could just be a buildup of things right there, as you mentioned before, including the vocals.
That helps a lot, thanks.
We can change the name. What would you all like it to be called?
What I found with both Addictive Drums and EZDrummer, the presets have a lot of processing out of the box.
Be the change you want to see.
