			Pinky
and The Brain...
This is why so many of us have nice home/car stereos to back up our guess work...
We would (should) be doing this anyway (that isn't the question here). Shifting mixes to/from other playback sources is tedious and never exacting (or a desirable means to an end). If this needs to be done a lot, then IMO the monitoring setup needs improvement/isn't any better than the 'other' supposedly inferior playback sources that the mixes are being run through. I rarely make changes anymore based on playback outside the music room. I still do it, just to be sure, but it's not the primary tool to accomplishing the mix.
I was once a fan of using compromised gear and getting the most I could. Then as I learned more it became apparent that certain things could be compromised, others could not. Quality mixing headphones and monitors cannot be easily substituted.
		 First off, I couldn't afford the room in which to make those Neuman/Focal speakers do their magic.
		 I'm imagining the "this" in that scenario...I still think we're semi-agreeing...which is actually NOT agreeing, but I can see your point, and I'm sure you can see mine. What you are looking for is a cessation of KRK5/LSR305/4"Cube recommendations based on their total unusable nature.
