andrushkiwt
that might sound confusing. let me clear that up...
For a guitar track, I used Amplitube 4 with delay/harmonator/octave pedals before the amp/cab. At the end of this current track, I play the final note and then that exact combo of pedals leaves a long sustain of ringing verging on feedback. Cool. That's exactly what I wanted.
But then, after I print the track (save some resources in the DAW), the ringing stops and the track ends with the final note. Yes, I "cut" and faded, quickly, the waveform after the note because I usually make some noise with the guitar while putting it down. The easiest approach would be to simply hold still for a few seconds after hitting that final note and let the guitar do its delay thing or whatever "wanted" noise it's making. But I don't always remember to do that. So, the feedback didn't print. The bounced track literally stops with the final note and any ringing doesn't carry over.
Is my previously mentioned idea the only workaround/fix here? To record it with empty space after the note? Just checking if there's any option I'm using or not thinking of.
thnx
thnx
