Do In eed to sand my git down if it doesn't have a lacquered finish? My guitar has a very flat finish, almost looks like that's the color of the wood itself, though I know it's not.
depends on what you mean by 'sanding it down' ..... you're gonna want to hit it with some sandpaper if only as a form of cleaning to prep it to accept the new paint.
Sanding will make sure you don't have any oils on the surface and it'll rough it up a bit to make the paint adhere well.
I understand the desire to rush it ...... I'm in the early stages of building a 335 and I'm having to hold myself back ...... one step at a time ..... next step for me is to shape the headstock ... the neck has a paddle and I need to cut it down to a headstock I like ..... no point in doing squat 'till that's done .... then I need to test fit the neck and make sure I have:
1. The proper back-angle so the strings will hit the bridge not too low or too high and
2. Make sure the strings will be correct side-to-side ....... don't wanna glue that neck on and find out the E string misses the bridge!
This'll take a couple weeks prolly since I have limited spare time.
Meanwhile what I really want to do is GLUE IT ALL TOGETHER .... SLAP SOME PAINT ON IT AND THROW IN SOME ELECTRONICS AND PLAY IT!!!!!
*BREATHING HEAVILY*
But I'm gonna take my time and try to get it right.
Now, I'm making a player and I'm just gonna grab some laquer at Lowe's ..... put three or four thin coats on it just to keep dirt from getting in the wood and I'm done.
But for any paint job, the prep is far more important than the actual painting.
The paint will come out as good as you prep it to be.
It depends on how much you care, of course ...... but if you want it to look good, do the extra prep work .... sanding .... filling grain except that, in general, if you're painting over a finish, then it's already grain-filled .... they almost surely did that to prep it for the original paint and even if they didn't, the paint itself acts as a sealer so I'm not sure you need a grain filler.
