Nola
hi everyone.
what's the proper way to use reverb on guitars that are panned left and right?
You can do any of those. Each will sound a little different. Go ahead and try each, just to see how they offer a different effect. Once you know what each method does, you can choose the one that is appropriate for what you are trying to accomplish.
That said, the normal mono in->stereo out reverb works well in most cases. In an actual room, if you have a guitar amp on the left, the direct sound of the amp will be on the left, but that sound will excite the whole room. Effectively acting like a mono in->stereo out reverb. (at least until you get into a huge, warehouse type space)
It probably sounds strange because it creates a completely unnatural effect. Effectively, what you are doing is putting each guitar in a separate, long narrow room, with the guitar amp at one end. Then standing in the middle with the amp on one side and the empty room on the other. That isn't how you listen to a band, or even just two guitar players.the reason i asked if that when i used mono reverb and panned hard left and right the reverbs sounded weird. they almost sounded like they had artifacts all the sudden and seemed real short.
i had a predelay of like 50 on them too. but i ran both guitars through the same mono reverb so maybe that's why.
i didn't try stereo yet so i will and see if that is more normal sounding.
If you stop and think for a moment about how the impulse is recorded, I think you'll see that it kind of can't be any other way. Say you set up a stereo pair of microphones and pop a balloon. The mics don't have any idea where the balloon is in relation to them, just what actually hits their diaphrams. Pop two balloons at once. The mics still don't know what part of what they're hearing come from the one on the left or the one on the right. No way to sort it out.Thanks Ash. Very helpful. I had not realized that ReaVerb sums to mono before splitting the signal to stereo. I'll try the dual reverb trick. Would this be the procedure? 1. Set up two reverb tracks, panned left and right. 2. Set up two separate sends from a mono track, one to each reverb track. 3. Adjust the panning position of the reverb-to-master return by balancing the send levels from the mono tracks to the reverb tracks. Am I on the right...er...track...here?
If it's a stereo reverb, I leave it in the middle and stereo. If it is a mono reverb, I pan it opposite the guitar feeding it.
