Can you slow the ping pong speed a bit? Might pull it into the groove of the song better...just a guess. Then just run a straight hall reverb from the second verse. Use it for effect and then let the song take over.
Needs a bit of beef on the electric guitars. They sound awfully weak, like they have way too much distortion. The lead tone is decent, though.
Nice vocal. Cool song.
The reverb on the vocals with the rest of the instruments doesn't sit right. I am not an anti-reverb guy, but it doesn't seem to fit the rest of the mix. Nothing else stood out in a negative way.
the space everything sits in for the first half is awkward - things aren't sitting right together, it's probably the reverb everyone is mentioning. the electric solo is nicely played (reminds me of Old LA Tonight, by Ozzy. almost forgot about that song) but needs to be rerecorded or mixed...it's too bright and lacking any bottom or mids, IMO
Promising start, but there are some things to fix. The vocal is too wet for my taste. I'd have it drier and more up front. Timing-wise, the whole arrangement could be tighter. Guitars, bass, drums, aren't locked in as tight as they could be. That distorted guitar that comes in midway through sounds buzzy and lacking in power. If you're doing a power ballad kind of thing, where you start lighter and get heavier, then you need to drop some of the "lighter" elements like the acoustic guitar as the "heavier" ones come in. As it is, the heavy elements seem bolted on, like an afterthought.
