PSSL Killer Deal (9-27)
  • Thread starter Thread starter Paj
P
Paj
SORRY: THIS SHOULD HAVE READ "9/28"
$40! + shipping (~$13). I bought a few.
MXL LSC-1 Handheld Vocal Condenser Microphone | PSSL
MXL LSC-1N Handheld Vocal Condenser Microphone
Features: •Interchangeable capsules for three mics in one
Specifications: •Type: Pressure gradient condenser microphone
•Diaphragm: Gold-sputtered, 6 micron diaphragm
•Frequency Response: 20 Hz-20 kHz
•Polar Pattern: Cardioid/Omni/Hypercardioid
•Sensitivity: -45 dB re 1 V/Pa
•Output Impedance: 150 ohms
•Equivalent Noise: -16 dB (A-weighted IEC 651)
•S/N Ratio: 78 dB
•Max SPL for .5% THD: 148 dB SPL
•High Pass Filter: 18 dB/octave @ 150Hz
•Power Requirements: Phantom Power 48V ±4V
•Current Consumption: 5.2mA
•Size: 7"x 2"
•Weight: 0.8 lbs /362.87g
•Metal Finish: LSCN Nickel / LSCB Black
. . . and, according to this article,
MXL LSC-1B | RecordingHacks.com
. . . the capsules are the same ones used for the 603s/604, so this may be a cheap way adding Omni & hypercardioid to your 603 and hypercardioid to your 604.
Paj
8^)
Just checked and still available for $50.
UPDATE: (10-3-15): The LSC-1 is still available for $50, new. I got mine on 10/4. They come in a plastic case, 3 capsules, clip, cleaning cloth, & 25-ft MXL/Mogami cable. Seriously, check them out. If you don't have a hand-held condenser, this isn't a bad place to start.
Paj
8^)
This is probably the last PSSL "Killer Deal" I'll post---I'm starting to feel like a spammer. If you like the Daily-deal type email, then sign up. It looks like PSSL has a line on liquidating MXL stock. That said:
10/7/15: MXL 2001 LDC anniversary. $50. Something doesn't jive in the noise specs but I have seen a review where the reviewer comments about a lower than expected noise floor. This mic has been around since about the turn of the century and has some interesting mods associated with it, including turning it into a tube mic (the recordinghacks.com link has info/links). Personally, I have no experience with this particular mic.
https://www.pssl.com/MXL-2001-SE-Sp...medium=Email&utm_term=KDD&utm_campaign=KDDALL
MXL 2001 | RecordingHacks.com
Paj
8^)
I use the 2001 extensively. It's a fair bottom end (cost-wise) mike. Mine's black on black though, not gold on white. I should get a second one and do the tube mod...$50.
9-30-15:
Paj
8^)
11/11: Back down to $40 + Shipping ($13 for me---I'm on the opposite shore).
Paj
8^)
Today (11-21) at PSSL: MXL Tempo XLR for $30; MXL LSC-1 for $40; MXL 2001 SE Anniversary $50; MXL 2001A + MXL 600 Recording Pak for $60.
Paj
8^)
