Reaper crashes when making changes in ASIO config.
  • Thread starter Thread starter davidwaldrop076
D
davidwaldrop076
Before I get to the issue, let me talk about the rig. It is as follows:
Behringer Utragain Pro 8
Digi 002
Reaper
Windows 7
HP xw8400
Here is the issue. I can't get Reaper to allow the Behringer to be the master clock. When I try to switch the master clock or make any changes in the ASIO configuration. Reaper crashes. The end result is relentless clicks and pops. This continues even if the sample rate is set the same in Reaper as the Behringer. The same rig works fine with ProTools but, I'd rather get Reaper to work as I don't own ProTools.
Any help would be appreciated
Reaper forum is your best bet on this one, I think.
However, do you need to allow the Behri to be the master clock? Why not let your system do that, i.e. set it to internal?
With two or more connected digital devices one of them has to the the master.
