The only thing I could think was a high pass filter (50hz or so). I was wondering if I could set up eq on an FX track and cut out all the low end, and send all the tracks there so I don't have to add a HP on each track. Then the tracks that needed more refinement above say 50hz I'd fine tune via an EQ insert.
The reason being half my tracks I don't use any EQ other than a HP filter, so it seemed like overkill to keep putting them on each track.
I guess that's not a good way to go about it, though. So inserts on each track are the standard way to go about it?
Thanks, dudes.
Yeah man.... a EQ on each track should be very very minimal load on your machine, unless you are working with a really tired or challenged computer. Don't sweat using a bunch of em... It's nice to be able to fine tune the frequency of each too....
I don't just blindly throw Highpasses on every track.... it is not needed on some. Others it is.
I don't highpass bass guitar above 30 or so unless it actually needs it higher, but maybe I actually want my kick passed at 60. Or maybe I want my kick in/out mics passed different. Follow? A lot of the time I'll use no highpass at all if there isn't anything gross sounding down there... on any source. Keep in mind that rolling that off effects the perception of other frequencies. Play around with this. Experience is going to show you a lot.
I use Waves Q10. For almost everything. My GO TO eq. With 10 nodes, I can High Pass, Low Pass, Shelf, and notch cut/boost, all in the same plug, so it's a no brainer for me. Hands on control of the nodes. And it's Clean. Surgical. It's not going to change the sound of your source just by instantiating it - it's not colored like that. This is why I love it. I'll sometimes use other EQ's later in a chain, but that's more for color, not for getting technical with EQ. I'm fast with Q10, and it doesn't get in my way. One of the biggest things to me, is workflow (second to sound quality). Maintaining good workflow, vibe, inspiration during the mix process is huge to me. If there is anything that slows me down, or hinders me, it can be a total vibe killer, and distracts me from the mix and what is really going on.
If you don't have a good parametric EQ with multiple nodes/bands, then I suggest getting one.
Good luck!
