PlatinumAudio
Hey guys,
I'm an ITB guy as far as mixing has been concerned, but now I'm going hybrid I have some routing confusion I'd appreciate help with!
I use Cubase 7.5, which allows hardware processors to be used as plugin "inserts" and I do understand how to set them up. Where I get confused is outside the box, because I don't have a mixer.
I have a 500 series rack that offers only XLR inputs and outputs (two sets per channel).
I have a 16 channel format converter with DB25 I/O.
So evidently, I have no immediate way of creating insert connections, but I am also struggling visualising the best solution and this is where I'd greatly appreciate suggestions for how to set this all up!
Basically, I will have pre-amps in one rack, which I will just connect directly via XLR/DB25, and all signal processing modules in another rack, which I would like to interface with Cubase as inserts.
Many thanks in advance.
Cheers,
Dylan
Cheers,
Dylan
