4
4tracker
Guest
Can you guys suggest a preamp to use with this machine, and do I have to reconfigure the jumpers to use a preamp with it? My ribbon mics are pretty low with the built in preamps.
Which ribbon mics are you using?
If they have built in preamps, I'm thinking they might be AT-4081s? Those require phantom power to power the built in preamp in the mic. Otherwise, most ribbons do not require phantom power and can actually be damaged by it.
Ribbons are also traditionally used for mic'ing up guitar cabinets or on drum overheads...two pretty loud sources which should require very little gain. If you're using them for those applications, you might not need a separate outboard preamp and maybe just a phantom power box if these are the AT mics I mentioned and an xlr to TS transformer adaptor plug to go straight into the 244's mic input. Also, when you turn the trim down on a 244 preamp, it effectively becomes a line level input so there's no need to make use of the accessory send receive ports to plug an external preamp in unless you're really ocd about bypassing one small gain stage.
As well, if you are genuinely needing an external preamp, you might want to specify a budget so that people can make more valid suggestions. No point in telling you to buy a Neve or something really exotic if its way out of your price range.
Cheers!![]()
Do you ever foresee recording four signals all at once? I'm just asking because you mentioned you're mostly recording female vocals and, unless you need to record four sources at once, you don't need a 4-channel mic pre and could most likely get by with a 2-channel, of which there are many more available --- not to mention your budget would buy better quality if you only needed two channels instead of 4.
I've used a Shure M67 mic mixer that's been converted to 4-channel outs, that sounds pretty good but I'll tell you now that you won't get any more level than the preamps built into the 244's mixer.
Am I correct in thinking that you want to take the jumpers out of the back and use the RCA channel inputs?
I've never used an external preamp with the 244, as I've never needed to. The 244's preamps always seemed to have more than enough gain for my cheapie MOR mics.
You may use an external preamp & plug it into the normal Mic/Line (1/4") inputs, using the transformer/adapter as necessary & keeping the Trim all the way down, & I think that's the best solution. All you're looking for is extra gain for your mic. There's the idea that putting 2 preamp stages in a row is undesirable, but I don't see a huge downside to that. If you require even more gain you may turn up the 244's Trim control as necessary.
Alt, you may remove the jumpers and plug the external preamp directly to the Access-Rcv patch point, bypassing the 244's internal preamp, but I think the hazard you run into there might be by also bypassing the OL LEDs on the input stage, and therefore having no indictation but your ears to determine when you're driving the downstream circuits with enough or too much gain. I've seen more than a handful of Portastudios with burned out channels due to plugging external preamps into them. It's a hazard to watch for & consider.
That's from recollection & I've not checked the 244 schematics. Maybe check later when I find the book.
Thanks, Dave. That's exactly what I was looking for with a better explanation of when to bypass the jumpers. I really do NOT want to do that, because I just had my 244 restored to spec, and I don't want to fry anything. So my best bet would be a pre-amp with the trim all the way down. Since the 244 only takes the hi-z mics, I assume the output of the preamp would be a xlr to a 1/4" transformer. So I'd need 4 transformers. Is that right?
The main reasons I can see for wanting to use external preamps are:
1) The sound: Different preamps sound different. Although it may be subtle, it's certainly more pronounced if you're talking about a tube pre.
2) Using condensers: An external pre will usually always supply phantom power, so there's no need to buy an external phantom power supply if don't need to. (I know he was talking about using ribbons, so this doesn't necessarily apply to his situation.)
3) Convenience: If you already have an external pre but don't yet have any XLR-to-1/4" input transformers, then the external pre will do that for you. This is especially true if you, like me, have the outputs of your external pres and inputs to the 4-track wired into a patchbay.
Not necessarily. It depends on the preamp. Many of them will have both XLR and 1/4" outputs. So I'd check before I bought the transformers.
