S
SR Krishnan
What is the usual and most frequently used order of the processing chain in the master channel to get fat, loud and crisp master?
Why the limiter? Just in order to make the whole thing louder, right?
My feeling it is generally more true for folk than for rock. Although rock might generally be overall louder, with a pile of instruments belting away there's often not many quieter bits. If you are recording a folk group, I would expect there to be more spaces, and hence bigger variation from load to soft.
Then again you can get spacious rock and dense folk.
That confuses me then (what both of you said), because I would have thought that a folk mix would naturally have a greater peak-to-average ratio because of a greater dynamic range - you want it to sound a lot like it does in real life, right? What am I not understanding here?
Rock' or whatever the sound of the limiter reigning in the snare' ..or the band for that matter can be part of the vibe. Not so much lighter/acoustic music (being very general here.What is the usual and most frequently used order of the processing chain in the master channel to get fat, loud and crisp master?
And most of that potential is decided before the "RECORD" button is ever pressed.Practically all of what makes a master fat, loud and crisp happens at the mix stage.
The simple answer is that you just don't limit that kind of mix as much and you let the listener turn it up.That confuses me then (what both of you said), because I would have thought that a folk mix would naturally have a greater peak-to-average ratio because of a greater dynamic range - you want it to sound a lot like it does in real life, right? What am I not understanding here?
Good, cuz I haven't been putting a limiter on any of my stuff. I haven't had anybody in the Clinic tell me 'you need a limiter on that mix' either. But I'll try it to see. Thanks.
That's why I'm going to explore it.As for why I've never used a limiter, that's easy - I've never seen the point. Probably because I don't know what it's useful for.That's why I'm going to explore it.
My mastering chain is eq, compressor, limiter. I should point out that often the limiter is often only grabbing the occasional peaks and not slamming the track. If I an mixing an album as opposed to 1 track I will have the eq, compressor on each song and the limiter on the whole album, again only grabbing the occasional peaks.
Alan
dense folk.
I think when people are first starting out the tendency is to try to master the song in the mix session on the 2 bus.Yeah, it's all good. I've only recently started paying attention to what I put on the master buss. I used to just mix and let the outcome take care of itself. But once I've nudged and tweaked everything in the mix as far as what passes for skill can take me, I find it's useful to address the whole thing on the master buss with some subtle tweakery.
