S
Spazhands
'ere mate
Well almost. I am a live sound engineer at my local venue and I have been tasked with mixing an outside show for a small festival. I am limited to certain outboard gear, which doesn't consist of any effects units.
. I will be using a Yamaha mg24 desk, so analogue.
. Here is my plan, I would like some compression, gate, eq and other such things at my disposal. So I was thinking about using my recording rig with reaper for this. I have an emu 1820m and could use the effects within reaper as inserts on certain channels eg kick, vocals etc. I have a maximum of 6 "inserts". I have done the routing at home and seems viable. Can anyone see any issues with doing this besides the reliability.. But then I could just pull the insert cables from the channels should the pc throw a wobble. I have used this system for recording for years and it only froze up once.
What do ya think?
What do ya think?
. I dont usually use compression on channels when doing live stuff but due to anticipation of bad mic technique from inexperienced artists and the possibility of wind screwing with things i feel having a gate etc at my disposal could be handy. The pci system has zero latency hardware monitoring and you can insert effects on the channel strips so in theory if I don't go through reaper it should be very direct as i wont be using any plugins at all. As I said I can always pull the insert cables should anything go wrong on the pc side. Is there any way of measuring the latency of my interface/ converters?
Yamaha mg24... How about barrow/rent a multi track a/d, use the available four groups, aux sends and/or ch insert outs to track channels and or sub mix/stems?
