C
chad kennith
I just found out about these. Could you recommend a good one to record a bass guitar? Also can you record your instruments straight into an audio interface, that has a preamp? Thank you.
The line input presents a 10K Ohm impedance, which is way too low to get any useable treble from a passive guitar or bass. It works sometimes as a half-assed cabinet simulator, but if you're going to an amp sim after (or re-amping), we generally don't want that.Timely post. I go into my interface, but I am now starting to experiment with micing and I'm thinking about picking up a purpose built DI box. Coincidentally, I was looking up bass mic techniques on youtube today and came across this video on DI vs. line in -> https://www.youtube.com/watch?v=dewuieQtm3Y
Granted, it might be the case that there are other factors, but *if* all other things are actually equal, there is quite a remarkable difference between going line in and going through the Radial J48 first, just based on this video.
A DI box, whether passive or active and including the DI/Instrument input on an interface, is designed to present a much higher impedance to the pickups so that you can keep a lot more of that treble. It's only kind of the DI that's responsible for the brighter tone here, but it's really the interaction of the pickup with it's load that is making the difference.
I record passive guitars and basses through a buffered guitar pedal (lately usually my Boss DigiDelay, since my DIY booster died) and then straight to a line input. The pedal shows the guitar somewhere between 500K and 1M - much closer to what an actual amp might present - and has no problem driving the line input, partly because it's not inductive.
Impedance is actually a pretty complex topic (really, like with imaginary numbers and stuff) that can take a while to get your head around even when you're deliberately studying electrical engineering. The quickest way to explain it is that it is like Resistance, but can different at different frequencies. When you see a number listed for most things, it's for some frequency in the middle of the spectrum, or sometimes over some range of frequencies that are considered relevant. It can have an impact on the signal level that gets through the circuit, but is not itself a measure of of level. A lot of people confuse the two. Try not to be one of those people.I'm a bit of a knuckle dragging sort of "musician", and I am having a little bit of a tough time grokking this. Can I ask for a little bit of a dumbed down version of this information so that someone who is of the sort, "me plug in guitar, me make pretty sounds" can understand?
Impedance for dummies.
So, what does this mean, this 10K Ohm impedance? Without knowing, I am guessing that this is a measurement of the signal that the line in of my interface is expecting - or maybe this is one end of an expected circuit path, with the other end being a sound source. Does this measurement refer to the level of a signal, or is this a different characteristic of a signal that is not really the same thing?
You are saying that a DI box will present a higher impedance to the pickups. This is making me think that it is like completing a circuit, and it is all about matching the two end points properly for ideal electrical signal transfer.
A passive guitar has a pretty hefty resistance across all the frequencies. A light-wound single coil might 1.5K at DC, while the hot-wound humbuckers in a couple of my guitars are 15-16K. A typical LP PAF-style pickup will be maybe 6-8K. So if you were going for 10:1, you might think that 100K or so might be good, but remember how I said that impedance can be different at different frequencies? Well, the pickups in our guitars act as what we call inductors, which means that their impedance gets really big at higher frequencies. In order to get as much treble as possible out of them, we really need the input impedance to be as big as possible. The pots in the guitar itself, and the cable between the guitar and its first active stage complicate things a bit, but we're trying to keep it simple here, right?What does a typical guitar, say a Les Paul put out and why is that not good for straight into an interface? I am guessing that the use of a DI box (such as the aforementioned Radial) will, by design, take a guitar signal and 'turn it into' something that is better for an interface, thereby giving a more 'accurate', 'full' or 'balanced' raw tone?
In short, is it really just sort of 'truth' that "me plug guitar in DI, me make prettier sounds now"?
