BTW, who's Ian?
It is so good to know that real rock lives and is doing well!! I like the battle song so much![]()
The preverb is really kinda simple. I recorded the vocal track. I moved the vocal track 300ms backward. I made a parallel track with 100% wet plate. I then ran the original track through a 300ms delay. You hear 300ms of the plate reverb before you hear the vocal.
The vocals have 1k pushed a bit and it brings them forward and clear (to compensate for the plate). I'll pull the vocal bus back and that will pull the vocal and the effect off a bit.
The instruments are mostly, just over compressed. I just got my monitoring situation fixed and I've yet to go back over my stuff. I'll pull a bunch of compression off as well and then compress as a master with Density.
If you hadn't heard, I bought M-Audio M3-8s and they're 220W each. So I had to pull the volumes back on the masters when I listened to my music (which affects the compressors greatly) and when I pump the mains back up to render, it skews the compression really hard. I just hooked up a splitting mixer so I can pull the volumes down on both sets of my monitors (Rokit 5's) and listen to either/or. Also just learned that the best way to apply mastering compression is to a stereo limiter from a stereo track, not on the master bus...This whole show is a constant learning game.
Listening to mix #2...
Sound quality overall is pretty damn good. The low end sounds terrific here. The vocals are indistinct, masked by the reverse reverb. I'd use it more as a spot effect rather than over the whole vocal.
I like the guitar wall of sound, although it gets a little tiring after a while. I think that each guitar (rhythm/solo) and the keyboard all need a little more room to themselves, they seem to bleed together in the EQ spectrum, creating a wash.
Nice playing on the guitar, and a good 80s metal song! I'll leave my comments on the subject matter at the door![]()
Thanks for the preverb tips! I'm definitely going to borrow this from you. It really does sound awesome.
Makes sense what you are saying about the compression. It must depend on the DAW. I use REAPER, and it has a post-FX fader, so it doesn't affect any of the FX that are sitting on the 2-bus. It's really nice.
8 inch woofers
Now that is serious business. How do they sound? I used to have a pair of M-Audio AV40's. I didn't like them at all. I found them to be very, very inaccurate. They actually sounded good, but consumer grade bookshelf good. That is of course, not ideal for mixing as they always hid the truth from me.
The M3-8 look like a different story altogether.
