dobro
So if you mix and record in the same room, you can record mics with the monitors on, and the mics will pick up both the sound source AND the monitors playing the sound as well. Have you ever done this with a good result?
Though, I have read that there's a way to invert the polarity on something or another, and set up with the mic and speakers forming a triangle or something, which is supposed to cancel out the bleed or something. But I wouldn't bother.
This ^^^ was the same question I asked when I read the OP. The only time I ever had my monitors on and a mic activated at the same time (in a 15' x 12' room) I got massive feedback. My eardrums might have busted...or the speakers...or the mic diaphragm...I dunno. It was painful though.Doesn't that just feedback?
...unless feedback (worst case) and bleed (best case but not ideal) are your thing...
Der...uh...If you're recording something with a mic, then you can hear it in the room. If you can hear it in the room, then why the fuck do you need to hear it from the monitors? Turn off whatever feature is feeding it through the recorder back to the monitors. Can't feedback then!This ^^^ was the same question I asked when I read the OP. The only time I ever had my monitors on and a mic activated at the same time (in a 15' x 12' room) I got massive feedback. My eardrums might have busted...or the speakers...or the mic diaphragm...I dunno. It was painful though.
The main design feature makes a live vocal mic more resistant to feedback is the built-in pop screen placed close to the diaphragm. This lets the singer get much closer to the diaphragm thus exploiting inverse square law. If you could get that close to the capsule of a studio condenser you'd get similar resistance to feedback.
Worth saying that, besides the built in pop screen allowing you to get up close to the diaphragm, they also have a frequency response curve designed to compensate for the proximity effect. This is why mics like the SM58 sound so thin as so as the source is more than a foot or two away.
