O
offnote
Hi,
I am recording digital piano on my DP-24 but while monitoring piano sound
quality is not good, piano sounds like cut off, muffled. When headphones connected directly
to digital piano sound is perfect. What is going on, any tips?
thanks
p.s.
I may add the piano is connected stereo cable, left and right channel.
thanks
p.s.
I just checked the effects and dynamics as you suggested, they seem to be all off. BTW the correct description of the piano sound I get is like a phaser was added, but very subtle. Volume source level I think is ok. I tried different pair of inputs to be sure but the effect is the same. What else I could look for
Of course piano sound is very specific so you can easily hear any nuances, I have changed piano source for test to yamaha motif XS where source piano is even better quality then roland but same problem. To answer you last question I will try to run roland piano through digital recorder I have V-100 by roland and compare.
