luca.staffiere
Hallo!
I have a HP Compaq Presario CQ61 with an IntelCore2DUo and 4 GB ram.
It's not much and I only use it to record or mix a pair of tracks at the time. But a little upgrade I could do without buying a new one would be adding a second HHD. The one I have is 5200 rpm... is it worth keeping? if so, should I use it as a software HDD or as a file? wich one should be faster?
And more importantly, if I remove the DVD reader and only use an external one those little times I need it, could it be possible to install the second HDD there or do I have to take a SSD?
thanks in advance!
thanks in advance!
