I agree, except when you can't get the other players to play in time. In nearly every situation I have ever been in, studio recording wise, I have had to struggle with people that play in front of the beat. In order to not go completely insane I wind up speeding up which then causes the goddam bass player or guitarist to speed up and I finally just stop, tell the engineer to put a click in everybody's mix and start over. I love it when the players say the click is wavering or some other nonsense. I lay down a nice, even drum take with just enough "organics" and then the other players have to overdub their parts. I usually record to a scratch track that has been quantized and force everybody to overdub, that's how it is going to go anyway.
I hope some guitarist will pipe up about "a drummer should be a machine, it shouldn't matter if the other players are a little off". I'll give you 50ms of latency in your headphones and let me know how that works out for ya. Learn to play, ya stringed instrument hacks!
For sure. And
a) "people that play in front of the beat"-- Typically, that's called rushing
b) When you feel/see that happening around you- depending on the situation, the choices are look to the drummer (most likely), or the bass, or others that aren't messing it up or are leading, to keep it from metastasizing.
(Ok- non applicable word.
d) If the person -um 'expressing temporal license' is The King and you're there to make them look good - suck it up and make it happen.
To me if someone ever said 'the click is drifting', I'd know- from experience, 'No, that's
you, and what happens when your focus shifted back from 'all you' mode...
to 'while you were away..? This is where we are now.
I'm thinking of a drummer -local not big time or anything that got jaded with this kind of stuff and he'd hold it down, and let someone hang out to dry- until that 'someone' would finally notice. Then you'd get this big 'turn around and 'WTF?' look.
Mean time you got this awkward shit you got to play through. Gee, fun.
..clarify. Actually it was worse than that.
Holding the tempo is good, fine usually. He might not notice the drift or what ever at first, but then try to drag it
back to 'proper tempo' half way through a fricken song. Yikes.
