B
BeagleFaceHenry
Member
Ok folks, I'm in the thick of mixing a session my band recorded a week ago. I'm using Sonar X2.
I've gone through each channel and EQ'd and compressed as I felt necessary and I'm happy with the tone of each instrument. I have a rough mix, but I'm now to the point of wanting to automate the volume levels. I don't have much experience with automation, am I correct in thinking that once I create a volume automation envelope, my faders become essentially useless? I can no longer make subtle volume changes without playing with the automation, right?
I know I can disable the automation, but once it's re-enabled, the volume (and fader) jump back to the automated setting, right? So, disabling doesn't allow me to make changes that will hold true once I re-enable?
So basically, I'm hesitant to start automating, because I'm nervous that I'll create a lot more work for myself. How do y'all handle it? Am I missing something? Is there a way to raise/lower an entire song's worth of automation? If so, do I have to go through and select EVERY node and then adjust the entire envelope? I hope not, because I like to do my final mix with my eyes closed and ride the faders. I feel like using my mouse to grab nodes will distract me from my mission.
Thanks in advance!
-j
Thanks in advance!
-j
Happy recording!
There are 5 modes - when you click on the envelope button for a track, in the box that pops up near the top you will see "automation mode". Trim/Read, Read, Touch, Latch, Write. Trim/Read lets you adjust the overall track volume (or other envelope parameters) with the fader/control.
